Guest viewing is limited
Evening all, I’m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying another socket on the other side of the wall. My question is, where can I apply the fused spur? Do I need to connect the fused spur before current spur socket so the fuse supplies both the additional socket and the light on a 13a switch or can I add the fused spur supplying the light after the spur socket Would that count as more than one socket spurred? I’m not sure because it’s fused. Any guidance would be appreciated.
The 13 amp fused spur supplies the socket and also the 5amp spur to the light.
The fused 13 amp spur from the ring main can feed as many sockets as you like, as it can't be overloaded
Ok. But what about feeding the light? Are you saying I need two fused spurs? One for the socket and one for the light? Surely then as I’m only feeding one socket, I don’t need one but just for the light?
Yes, one to feed the socket and one to feed the light.
Or you could wire the socket as part of the ring and then fuse spur to the light.
Or you could use a 5 amp plug to feed the light.
I’ll see what I can do tomorrow and report back. The sockets are back to back so it might be possible to just extend the ring main
Extending the ring is best idea.
Gets a little crowded having 4 sets of cables at one point…. Ie, 2 off the ring, spur to socket, spur to light…
Buckinghamshire
Fused Spur feeding socket and a light
DIY Electrical Advice
Super Hans,
littlespark,
