J
jimk996
Go on Murdoch maybe you've seen what others haven't, give us a Regs No.to cross ref?
For ****s sake dedicated circuits don't count for anything anymore are you thick
Wirepuller ... this wouldn't comply regarding the 2way switch method as it would fall foul of 554.3.3 unless you were to have a double pole switch also which you failed to make clear in your suggestion.
I'm not taking sides here but lets say its added to the immersion circuit - then an inspection is done - my bet is on that its a C2 and fail for a shared circuit!!
I'm not saying it's a desirable situation, but providing the current carrying capacity of the cable is sufficient under all conditions of use, I wouldn't regard it as potentially dangerous and would therefore give it a C3.
