Hi everyone was looking for some advice on a job that I looked at last night. The house has a new boiler being installed which needs a supply to it. There is an existing cooker switch wired in 6mm on a 30A fuse going to a single socket which the electric oven is plugged into. There is also a switched fused spur directly adjacent to the cooker switch wired in 2.5mm which used to supply an extractor fan. Is it ok to connect the new boiler to this fused spur or is the cooker required to be on its own separate circuit? There is also no RCD protection on the existing old Wylex board which uses bs1361 fuses. Thanks in advance!
