View the thread, titled "Fused spurs" which is posted in Australia on Electricians Forums.
T
tok
Hello there,
I have my 1st assessment on monday and have a few questions about fused spurs throughout the house where i have changed the distribution board(nothing else).
1st I have a security light coming off the downstairs ring from the kitchen and i can't find any spur for that(and have no idea which socket it comes off), should i just note a deviation from the regs?
2nd i have a shaver socket in the downstairs toilet directly behind a light switch, does that need a fused spur? My thinking is there's not really any significant run of cable to protect?
3rd i have a shed (spurred off the kitchen ring) with 2 power sockets, and 1 lighting circuit that comes off a junction box(in shed) hence no fused spur for the lights although the cable supplying the lights is 2.5mm(same as socket), bearing in mind i thought fused spurs were primarily to protect the cable should i fit a 3 amp there or just note it as a deviation from the regs?
Thanks for reading.
ok as long as you are aware of the deviations and note them down, and then if they are picked up by the assesor you can answer any questions on them
I just read the Best Practice Guide for changing a consumer unit downloaded from the ESC website, and it does say on 6.1-6.3 that the earthing arrangements must be adequate before work is begun :o
thats right and you begun your works before they were. schoolboy error.
keep us posted on how the assessment goes
how did the assessment go tok??
how strange i thought i had replied!
The assessment went ok, the assessor said that the bonding had been "adequate", and i promised to finish upgrading it to current regs.
All the extensive testing i did was a bit wasted as he was more interested in the fundamentals and was happy with how the certificate looked, plus i had all the paperwork prepared.
I was ready to impress him with all my knowledge of circuit design, regs etc. , but he didn't really quiz me very much!
well done, i reckon you had a right result there :p
out of interest, which scheme was it with??
Reply to the thread, titled "Fused spurs" which is posted in Australia on Electricians Forums.
