Fused unit no longer required | Page 2 | on ElectriciansForums
Discuss Fused unit no longer required in the DIY Electrical Advice area at ElectriciansForums.net
Pull the cables up/down and joint them under the floor or in roof space, fill the hole and paint over.
If there is a nearby socket that provides a safe zone for that cable position then you can crimp and heat shrink the cable together and then plaster over it.
If it is not in a safe zone then you cannot do this.
To do a nice job would be to replace the cable between the two sockets either side of it but this would be significant amount more work.
Reply to Fused unit no longer required in the DIY Electrical Advice area at ElectriciansForums.net
As a trainee, one of the things I've tried to focus on to deepen my interest in the world of electrics, is the space for creativity. I've...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
