Fuses and tails. | on ElectriciansForums
Discuss Fuses and tails. in the UK Electrical Forum area at ElectriciansForums.net
scotland
hi there doing some work with my gaffer just for my own mind a 60 amp fuse at the main cut out with 16mm2 tails well i assume they will be what size of main switch for the consumer unit ? could 100A main switch be put on that ?
yeah thanks guys my boss said no isolator what fuse will he pull will he pull both? he’s a bit crabbit when i ask things
  • [ElectriciansForums.net] Fuses and tails.
He shouldn’t be pulling either, unless he has permission from the supplier.
(Or the seal fairies are smiling on him)
And if he’s crabbit when you ask him questions, then ask to work with someone who does want to teach you things.
he will usually contact the supplier and asks for permission just curious s what fuse he will pull
you but could 100 amp main switch be used ?
[automerge]1574191332[/automerge]
just for my own mind it the pictures previous what fuse will he pull will he pull both or just one?
[automerge]1574191354[/automerge]
Forgot to finish my last post. I intended to also ask what the job was that was to be carried out?
new main board what fuse will he pull tho
Reply to Fuses and tails. in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
This was posted this week, on topic ....... https://niceic.com/newsletter/omission-of-overload-protection/?dm_i=7G1W,7GCE,K4L2A,WHET,1
