K
Knobhead
Anyone worked on GEC System 4 gear?
Got a phone call this morning from an old mate Dave. He’s had a switch getting hot for a while purely down to increased load. Last weekend he up rated the switch from 400 to 630A but down rated the 630A fuses to 500A. It’s a dead easy job to do, 400 & 630A units just plug in to the same frame. You can even do it with the main board still live.
The new switch was now getting hotter than the old one.
Many years ago I had shown him how to hot swap or add new switches. So he calls me.
About 30 years ago I had a board with several switches overheating so I took one out and stripped it, couldn’t find any thing wrong with the switch at all? Stripped the fuse carrier down and between the fuse lugs and the switchblade I found a hardened steel plate. The plate was supposed to be between the nuts and the fuse lugs. Told Dave just to check the fuse carrier and he found the same thing, he’d changed the fuses and put it back together the same way as he found it. I asked where did you get the new switch? “Oh it’s been in stores for god knows how long”!
Same bloody batch that got me all those years ago!
Don’t get me wrong I still think System 4 and MiniForm is fantastic gear and it’s still available. I just hope they put it together correctly now!
Fault finding by remote control, just waiting now for the bottle of VVSOP brandy to arrive!
