fuses in series | on ElectriciansForums
Discuss fuses in series in the Australia area at ElectriciansForums.net
soulman
Durham
sorry another question! just doing a bit of homework on a sunday.
why would it be wrong to connect a to a 3036 fuse then to a rcd to a mcb then to the load
cheers.
hi i have just read previous post on rcd protection. where on guy was trying to put in a shower, wired directly into 3036 fuse then into a small consumer unit through an rcd into a 40a mcb then to the shower the response was fuses in series is bad practice i couldn't understand why?
as it was 7.5 kw shower the 30a 3036 will support this and so would the 40a mcb so i thought double protection.
cheers
cheers
thats the point i was getting at. if there is a rewirable board and customer wants an electric shower the only way to achieve this is to feed an rcd from the existing rewirable.
not ideal but not wrong
If a Customer wants a shower put in and they have a 3036 Fuse board, you either need to change the board or split the tails. Bearing in mind alot of 3036 boards only have a 60A Main switch, I wouldn't install a 7.5Kw load on one.
Reply to fuses in series in the Australia area at ElectriciansForums.net
What makes it a lack of space? I’d say to the customer to dismantle a cupboard or whatever to creat the space you need for the extra equipment...
