N
nickblake
Here's a fault that was located after a couple of hours searching for it found the fault to a few inches i was impressed , i had installed safe plates over the cables but the plasterers took them off and proptly screwed 4 nails through the dam cable , but belive it or not i didnt show up on the testing just went bang 5 minuits after we'd powered up the system to do a Zs , tested the meter too just in case i was getting false readings
