garage cu + Napit | Page 2 | on ElectriciansForums
Discuss garage cu + Napit in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Is the CU in the house split load? If yes is it not possible to rearrange circuits so that the garage circuit comes off before the 2 rcd sections and so is not rcd protected. If the wiring to the garage is surface mounted am i right in thinking it does not have to be rcd protected - then you can have just one rcd at your garage . Feel free to shoot me down - i am just a beginner:p
Edit : oops hadn't seen there was a page 2 so didn't realise when i posted this that old dog had already suggested almost the exact same thing and thread had moved on- sorry!
It sounds like it is an existing split load board with main switch and one RCD.
And yes, provided the cable is surface mounted then it doesnt not need RCD protection.
Reply to garage cu + Napit in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
