Garage door stops working but | on ElectriciansForums
Discuss Garage door stops working but in the USA Electrical Forum area at ElectriciansForums.net
hayley3
Southern Indiana
If I unplug it, turn circuit breaker off and then on again and THEN plug the garage door back into the outlet, it works fine for a while.
How can I troubleshoot that to figure out the problem?
Thanks!
I do have a GFCI outlet that is not working too but it's on a different circuit breaker so I'm assuming it can't affect the other outlet, but not sure. I'm gonna buy a new outlet tomorrow. :cool:
@heyley is your garage door on a GFCI receptacle. Does it stop working while you are opening or closing?
Hi Megawatt,
The garage door is not on a GFCI receptacle. It does not stop working when being used. We go out and the garage light doesn't turn on, that's how we know I need to flip the breaker again.
@hayley3 Is there any more loads on that circuit and when you flip the breaker, is it actually tripped
The light is part of the garage door opener. So it only goes off when the garage door opener doesn't work. I probably was not too clear about that. :)
I just fixed the gfci outlet on the other wall. so that is no longer an issue and probably didn't have a thing to do with the garage door since they are listed separately on the circuit breaker panel.
Hayley the best I can tell you is you have got a loose connection in the controller but I suspect that a loose connection in the panel is your problem where the breaker is and with you flipping the breaker it makes contact again does that make since to you
[automerge]1570224706[/automerge]
I’m impressed with your knowledge about electrical
Thanks Megawatt for your help...appreciate it so much!
I live way in the country so getting an electrician is not the easiest thing to do so I have to learn to do some things myself. :)
I'll check for a loose connection first. I'll post back if I find out anything.
Please make sure the power is off on that panel, as long as you are doing that you might as well check all breakers and the ground bar. Good luck and please be safe
Reply to Garage door stops working but in the USA Electrical Forum area at ElectriciansForums.net
As long as the capacitor is an electrolytic and isn't of too low a value :)
Just doing some thread admin
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
