W
william7900
Hi friends,
I have been reading threads concerning garage earthing arrangements. Advice was given to extend the earth from the house to the garage. Please may I comment that this is a dangerous practice because if by accident someone went through the SWA cable with the mower etc, the result would be catastrophic, due to the fact that in the garden you will be in contact with the earth and a perfect conductor for electricity and receive a severe shock. The earthing system for a garage should always be TT, using earth rods and trying to achieve a resistance of 200 ohms. You may have to use more that 1 earth rod to acheive this. The garage unit should always be RCD protected.
This is why on building sites all the equipment is supplied by transformers which gives a separated environment and no earth is used for safety. Hope this helps.
Regards,
Bill
Regards,
Bill
