garage electrics | on ElectriciansForums
Discuss garage electrics in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
tamgunner
hi all i have just taken on a garage and im looking to put lighting in. i know the supply is a 24v feed coming in.
i was wondering if a fuse is out is the feed live or not? theres no switch and no bulb so i would need to fit a switch and a bulb.
Do you mean 24V or 240V either way all switchs fuses etc should always be on the live side dont however take that for granted and always check.
Hope that helps
Chris
Reply to garage electrics in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
