Garage & other external buildings | on ElectriciansForums
Discuss Garage & other external buildings in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Finished a Eicr,just your thoughts on this,the remote garage is supplied from the ring main of the house,other building are radials of this.
The supply enters from underground,& are pvc t&e,goes straight into a 2g power point,then to other points.
There is no main bonding required,thinking this needs isolation when entering the building,& other supplies protected accordingly.
Would you fit a small DB on the main in,or a complete no no,cause it’s a ring main.
.QUOTE="cliffed, post: 1372096, member: 11164"]Finished a Eicr, just your thoughts on this,the remote garage is supplied from the Ring Final of the house, other buildings are radials of this.
The supply enters from underground, & are pvc T&E, goes straight into a 2g power point, then to other points.
There is no main bonding required, thinking this needs isolation when entering the building &, other supplies protected accordingly.
Would you fit a small DB on the main in, or is this a complete no no, because it’s a Ring Final?[/QUOTE]
Personally I would tell your client that the work is the Dogs dodas, and suggest to him that its ripped out and installed properly. Waiting for the abuse to come my way. Corrected this for you makes it easier to understand.
I would give it a C2, an unsatisfactory report and submit the EICR with my invoice ................... remedial work isn't part of the EICR unless you've been asked to fix as you go along...
Is the garage part of the house ring ( :) @Pete999 ) or it it radial? Your post is not clear as it sounds like only the 'other buildings' are radial and not the garage. That is why you put "& are pvc t&e". Plural.
Are the cables in trunking/conduit or just directly buried? What is protecting these cables from damage?
If the garage is on the ring, what is the distance of the cable run from the house? If there is a load of extra cable on one side of the ring it is going to make quite unbalanced if there are large loads at other points (e.g kitchen close to the CU)
Personally I would tell your client that the work is the Dogs dodas, and suggest to him that its ripped out and installed properly. Waiting for the abuse to come my way. Corrected this for you makes it easier to understand.[/QUOTE]
Thanks,I might just do that.
Good question,I have no idea,the cables are coming from underground into the garage.
It’s the house ring main.
Reply to Garage & other external buildings in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
