Garage Supply Help!!! | Page 2 | on ElectriciansForums
Discuss Garage Supply Help!!! in the UK Electrical Forum area at ElectriciansForums.net
Rufat
London
Hi everyone.
I am new to this forum. I've just completed my C&G level 2 qualification and started on level 3.
Next week i plan to install a garage supply from the CU in the house to the two way CU in the garage.
I planned everything all wiring diagrams, layout and about to do a product list. The job will be tested by a competent person as soon as i finish it.
But before i start the job i wanted to make sure that everything is correct and need an advice on RCDs in this installation.
It's a TN-S system.
There is an old type metal consumer unit as you can see on the pic.
[ElectriciansForums.net] Garage Supply Help!!!
The supply to the garage CU is by 4mm SWA burried underground and properly terminated at both ends. The earthing will be extended to the garage from the house.
PVC 2 way CU in the garage supplying:
1) Lighting circuit 4x100w bulbs protected by 6A MCB
2)Radial socket circuit supplying 2x double sockets and a fused switch for a 200W pond pump protected by 20A (sockets will be used occasionaly for Power Tools such as hammer drill and circular saw
Cables:
1)1.5mm flat T&E clipped direct for lighting
2)2.5 mm flat T&E clipped direct for Radial
The questions is:
1) Should i add 20 MCB on non RCD side in the main CU and have a 30mA RCD in the garage connected to it?
or
2) supply the garage from existing 60A RCD and have a main switch with 6,20A MCBs in the garage (which will be easier and cost effective)
The outbuilding is only 5m away from the house.
Any advice and information much appreciated.
Regards,
Rufat
Employ a competent electrician?
Why should he, he's got enough knowledge to do it himself, he just wanted to double check it's all safe. At least he's seeking advice and not just going ahead without being sure. My guess is he can't afford to employ an electrician and seen as he's at college learning this trade, he might as well do it himself and gain some experience. That's what I've been doing as I'm sure you are aware!
Another thing... Aren't you meant to use 4mm on radial circuits, just in case someone comes along and adds more socket outlets? Especially if you end up using a 32a breaker in the garage.
Like you, installing a garden circuit which trips the RCD as soon as you plug something in?
If you have designed the circuit as a radial, and put it's max design current as 20A, then 2.5, under normal conditions, will suffice. If someone wants to change the design to increase it to 32A, that's not your problem. If they add more sockets the cable is protected by the MCB. (How many sockets can you have in a garage!) If the circular saw inrush current looks like it will trip your 20A breaker, use a type C. Hope this helps.
If someone is competent to complete a job, why on earth would they ever log on to an internet forum, where there's more BS flying around than anywhere, to double check they are correct in what they plan.
The last supply I did to a garage was done in bell wire. Its still going strong, saying that though, there are no sockets just a single light BULB:toilet:
So why are there so many fully qualified registered and experienced sparks on here slating everyone who isn't? Whats the point of them logging in?
A second opinion is better than nothing!
- - - Updated - - -
Understood.
I totally agree, but you don't understand how hard I have tried to get one. If you could help me find one i'd be grateful as I have been searching for over a year now. Even my local council aren't taking on apprentices any more.
I totally understand all the arguments about the lack of availability regarding apprenticeships, but the bottom line is quite simply that if somebody isn't qualified to do something, then they really shouldn't be doing it. Regardless of what I "think" I am capable of, I wouldn't pilot an aircraft simply because "I have tried to get training, but nobody wants to train me", even though I've had a bit of experience.
Getting an apprenticeship has never been easy, regardless of what people think. I myself originally travelled the length of the Country before I got offered a place 180 miles from where I lived at the time. It was while at that centre, that someone there put me in touch with another firm nearer to where I lived. It was extremely difficult to get trained, even back in the 80's and competition was fierce. Unfortunately nowadays, everyone wants everything handing to them with a nice big salary. I missed out on doing lots of things when I was younger, but that doesn't mean it's right for me to have a go now, just because I feel that "the time is right".
Reply to Garage Supply Help!!! in the UK Electrical Forum area at ElectriciansForums.net
Why would you want to fuse them? The RCD should now be a type A plus it is likely you could upgrade the protective device to 20A. What protective...
