Garage supply. RCBO at CU? RCCB at garage board as well | on ElectriciansForums
Discuss Garage supply. RCBO at CU? RCCB at garage board as well in the UK Electrical Forum area at ElectriciansForums.net
Dan59H
Putting in a garage supply for an obviously dearly loved friend,
My current theory is 32A RCBO at CU
then 4mm t&e to garage board.
garage board has an incoming RCCB
and I'll be putting 2 radial circuits and a lighting circuit on 2x B20's and a B6 respectively.
Is this going to provide discrimination when there's an earth fault on the garage circuit via the RCBO?
after reading a few threads looking for an answer to a different question I'm outfoxed by the RCD in series stuff
if you cant get your head around basics like this...
then you have no business installing.....for a `dearly loved friend`....
or anyone else for that matter...
Dear God!! If you have read the other numerous threads on this common situation and are Still ''outfoxed'' by RCD's in series, there really isn't much hope for you i'm afraid!!
Back for another 5 weeks at the training centre for you!!
Reply to Garage supply. RCBO at CU? RCCB at garage board as well in the UK Electrical Forum area at ElectriciansForums.net
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
Recommended Sponsor News
Hi everyone,
