uksparks
Hi,
i went ent to look at a job this morning where someone needs power to a remote garage in the garden, it's only about 8 - 10 meters away from back of house.
unfortunately it's not really feasible to run it on its own circuit for quite a few reasons, yet this would have been my preferred method.
is the general accepted method when coming off a ring to essentially create a lollipop circuit, so connect from ring to SWA back to small garage cy, is the accepted method just put a 13A FCU off the ring and run a bit of 2.5 swa to a garage cu?
obviously I'll check the zs and R1+R2 at point of spurring to calculate max length of spur.
is this what you would do if cannot get it on its own circuit? Or would you just spur off with 4mm and take that direct to a garage cy without the 13a FCU?
