Search the forum,
Discuss Garage switch stopped working after GFCI switch issue in the DIY Electrical Advice area at ElectriciansForums.net
stratus
I plugged a drill press directly into a GFCI outlet in the garage. Something blew up by the drill press switch.
Since then the GFCI outlet LED has not lit up. I tested it and no voltage is detected. I replaced the GFCI with another and it didn’t work either.
What’s worse, the garage door switch stopped working. It looks like the garage motor and light has no power.
Other outlets and light in the garage are still working and correctly shut off by the corresponding switch in the electrical panel box. The drill press also works.
Looking for any DIY advice before I call an electrician. Thank you!
If you replaced the GFCI receptacle did you somehow install the incoming power to the load side instead of the line side. If so it will not work. Good luck and welcome to the forum.
Reply to Garage switch stopped working after GFCI switch issue in the DIY Electrical Advice area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Upfront disclosure, I am a DIY homeowner with basic knowledge of electrical safety. Here is my issue: Type GFCI Outlet- Eaton TR Installed mid to...
Want to put a GFCI outlet on a circuit. Currently, this circuit is free of any other outlets or switches. Purchased an Eaton 15-Amp Tamper...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
I have a towel dryer on an interior wall in my bathroom, wired off the last stop in my loop of bathroom outlets. This thing has been installed...
