Garage units
A
antix_v2
Hi guys,
I've got a small job to do putting power into a large outbuilding. It currently enters into an rcd then into an old metal unit with one fuse way.
I'm thinking of taking it from the rcd into an MK 4 way ip65 unit, no main switch etc. Most the garage units with switches only do way.
Anyone used one as mentioned above? Without a main switch how does the live connect to the bus bar?
Anyone know the main cable size they take in?
Unit like these -
WWW.*************/prods/89333/Elect...er-Units/MK-Consumer-Units/MK-WP-4M-Enclosure
Cheers peeps.
Ant.
Maybe check if they supply manners/personality. I'll chip in for you.
don't forget the steak, medium rare, ( with the chip) , and as for personality, my psychiatrist has that in hand ( she had something else in hand last nite, but i won't go into that on an open forum)
