garage wiring alterations | Page 2 | on ElectriciansForums
Discuss garage wiring alterations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
your suggestion looks feasible
Reply to garage wiring alterations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You cant just "avoid" the use of RCD's for nuisance tripping... it will depend on how the cable is routed. (ie buried less than 50mm) What has...
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
