Garage wiring unsafe and not earthed | Page 2 | on ElectriciansForums
Discuss Garage wiring unsafe and not earthed in the DIY Electrical Advice area at ElectriciansForums.net
Triple core what? If it’s armoured cable then the armour will more than likely be the earth, not the third core, it it has been glanded correctly
@Pete999 and myself have asked what type of cable it is. Just waiting for the OP to reply mate.
Also according to the OP none of the sockets or lights were earthed.
Could that be dangerous as the local earth could be at a different potential to N? Or does it depend on the installation being check for that after install?
Your next step is to find a local friendly spark to come and determine what precisely is going on .......................making any further changes isn't a sensible course of action.
Reply to Garage wiring unsafe and not earthed in the DIY Electrical Advice area at ElectriciansForums.net
The 3A fuse is there to protect the current lighting. For additional power you connect from the non protected 3A fuse side.
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
