Garbage disposal wiring problem | Page 2 | on ElectriciansForums
Discuss Garbage disposal wiring problem in the UK Electrical Forum area at ElectriciansForums.net
Portland, OR
I bought a garbage disposal and had it installed under the sink by a plumber. When we attach it to the power, if the switch is turned on the disposal runs. When the switch is turned off, it trips the circuit breaker. I tried attaching a different switch, but it still has the problem. The clothes washer is plugged into this same circuit and works fine.
If it its a GFCI (or RCD) that is tripping, but is holding when the switch is closed, then there is no imbalance in the circuit. If a double pole switch is fitted, and one pole is opening very slightly before the other then a imbalance will be detected and the device will trip.
But until the op comes back and confirms what's involved then we can only speculate.
@Devon he stated it was on the same circuit as the refrigerator. That branch circuit is required to be installed as a dedicated circuit by the NEC and no GFCI is required. Having said that the plumber has tapped off that circuit which is not allowed. VIOLATION
I think the OP confirmed that it's the 30A MCB that's tripping.
Reply to Garbage disposal wiring problem in the UK Electrical Forum area at ElectriciansForums.net
Sorry for the late reply but if you don’t have it working garbage disposals are supposed to have their own circuit but I don’t know how old your...
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
