U
ulfr
Hello everyone,
I'm new in the industry, and soon will get 2 Level in Electrical installations.
At a class tutor gave us a homework, to make a diagram, and all necessary calculations for cable size, voltdrop, Zs, e.t.c What's needed in "real world".
I have a few questions about a schematic(?) wiring diagram, and in general. Pics are below.
For example, customer asked for 5 separate circuits(each of them will turn on individually), and 1 switch to turn all 5 circuits at the same time.
Length - 84m of wires required
Circuit 0 – all at the same time - 2140W / 230V
Circuit 1, 2 flood lights, 250W x2
Circuit 2, 2 beds 4 garden lamps, 120W x4
Circuit 3, 2 flood lights, 250W x2
Circuit 4, 4 tree lamps, 4 x 120W
Circuit 5, 4 brick lights, 4 x 40W
Questions are:
1) Is it possible to wire in that way, like in the pic2?
2) Which circuits are final here if a customer will turn on Circuit 0?
3) Customer can turn on circuits randomly e.g. 1-5, 1-2-3, 2-5-0. Then all circuits should be counted as final, and therefore 1.8 diversity factor should be applied to counting?
In that case:
Maximum demand = (2140W/230V*1.8(A1(Note 2)) * 0.66(A2) = 11.05A
Voltdrop (Reference method A)= (7.3*11)/1000*84=6.77V
Therefore, 6mm2 cable should be used. But it's quite costly, isn't it?
View attachment 25128View attachment 25129
wires will be buried in the ground.
Thank you.
Questions are:
In that case:
Thank you.
