Garden shed cable size | Page 2 | on ElectriciansForums
Discuss Garden shed cable size in the UK Electrical Forum area at ElectriciansForums.net
Ayr
Hi, I,m running a supply to my neighbour,s new garage and would appreciate advice on cable size. It will be 3 core SWA running underground. The max load will be around 8A and that only for small periods(power tools) other than that only lighting,and total run will be about 30mts from house DB. I advised him to get 4mm but now think 2.5mm would do. I,m ex maintenance and retired so am very rusty regarding design calcs.
Sorry to ask further, but if he decides to take his supply from ring main to avoid approx 15mt run under floor boards will same cable size(2.5mm) be adequate if I spur it via FCU
As above, i am all for helping people out but i draw the line at doing all the legwork when someone of sufficient experience cant form an answer of their own accord. I mean i asked a similar question but i provided the guys with all the info and showed the conclusion i had drawn with all the relevant calcs. I received lots of helpful info...
Although I agree with where your coming from here, I believe you first 2 posts contributing to this thread didn't help or give any constructive advice, it only baited for a negative reaction. You could have easily made the same point while been polite and in a positive manner, yes one of your comments was in jest but that only exacerbated the response from the OP.
Can we see less of the short quick trolling comments please and more positive replies, if you feel the OP is asking too much then there is more than one way to put that message across ;)
REALLY.
The OP states he's a spark with many years experience¬!
REALLY.
I'm not suggesting for a minute the reason for his first post was wrong, like I said, I agree with where he was coming from, my post was regarding how he makes his point and the way he put it across could have been better, it can only get a negative reaction when put like that, then following it up with the bellwire comment.
REALLY.
Yes, but mainly in maintenance and now retired 7yrs. When not using your skills much, your knowledge diminishes a bit. But you know your 3 posts to me have all been negative with no thoughts at all of helping someone. You and Lanky Willy do not do this excellent forum any favours. Many thanks to Davesparks and Telectrix
I think if your original post had been worded a bit better you may have got a better response, especially if you had included what you have just put in this last post. But it's sometimes tricky to get across the sentiment in words on a computer screen. It's the same with text messages - they sometimes get misunderstood (context etc.). At least everyone's happy again now. Daz
Spot on matey.
You come over as some desperate DIYer and I DO NOT help DIYer's with such problems.
Ib/In/It/Cf/Vd remember these ?
I'm unloved...... :(
Reply to Garden shed cable size in the UK Electrical Forum area at ElectriciansForums.net
