Garden supply | Page 2 | on ElectriciansForums
Discuss Garden supply in the UK Electrical Forum area at ElectriciansForums.net
HandySparks
Mentor
Hampshire
Hi All,
Detached house, about 15 years old, on an estate. Customer wants a socket and some light on his decking area at the end of the garden (for amenity, not security). It's bordered on two sides by brick walls (one is next door's garage).The easiest source is from his detached garage (supplied by a very short existing underground run from the CU in the house).
TN-C-S supply. Garage supply on 30A MCB on RCD side of CU in house (shared with kitchen sockets!). All other socket circuits are also on this single RCD.
Garage has 2 way CU, 16A sockets, 6A lights. No spare ways in either board.
I'm intending to take the garden supply via a SFCU with 13A fuse off the garage sockets circuit. Through wall to plastic adaptable box. 3 core 2.5mm² SWA, 30m long, down wall and underground to MK masterseal double socket on wall by decking. Short conduit link to double pole masterseal switch for lights. 1.5mm² HiTuf or NYY-J clipped to wall to each light (3off ?).
Any earth fault in the garden will trip out all the house sockets; not ideal but that's how it is. 2.5mm² is ok for, say, 2.5kW load (eg large garden power tool) and still be OK for VD on lights. 2 core SWA would be slightly cheaper, but I like the security of one core for the CPC. Not measured Ze yet, but it would have to pretty high for the Zs not to be OK.
The underground cable run will be in a narrow strip of gravel between the brick wall and a slab path. No digging likely but as it'll only be a few inches down, I'm inclined to supply a piece of
polythene cable duct for the customer to bury and then I can pull the swa through when he's done.
Any comments generally?
In particular on the supply to the lights being protected by the 13A fuse in the SFCU? I think it's OK. The cable rating is higher than this; it's only the wiring inside the lights (whatever they end up having) that may be a problem, but it's a small fixed load.
Does anyone know of some nice looking bulkhead lights or maybe some wall mounted spots that will take a surface run cable? Most domestic lights are designed only for back entry, which is not possible in this case.
Fully agree it's a good thing to use for extra protection and taped with warning tape and alls good. Was just one of those thing's that lingered in the back of my mind (as these things tend to do).:17:
Re. ducting - Tools...tion do some 15mm x 50m flexible ducting for £27 (#92505). A tight fit but you'd get 2.5 SWA into it with care. It's black too.
Thanks for that Rick. (The part no is 92502, I think.)
I suspect that the Toolstation stuff is more like the lightweight flexible conduit and therefore may not be much protection against an errant spade or fork (unless you've seen some and know different). Also, as you mention, it may be OK for short runs, but pulling in a long length of SWA needs a decent clearance in the ducting to make life easy.
While we're on the subject, if you need to get a pulling line into a duct (privided it's not too big on diameter), attach a vacuum cleaner to one end and it'll pull a piece of string through. Dead easy.
A bit of cloth tied to the string might help if it's reluctant.
When we was on site doing new builds in 80s and 90s the groundworkers used to lay a smooth bore black duct similar to the water pipe but larger bore
Can you get larger bores of this water pipe or similar
I have tried to locate this with no luck whatsoever, as i have just done a job for my brother.
Were I had to dig from house to a New large shed/ workshop at bottom of the garden the total run 34metres the actual dig about 25metres 500-600mm deep hard work to say the least
then he decided to ask me when i had installed some 40mm waste pipe with connectors all glued On the advice of a forum member and some of the blue rope which i had used to draw in the swa 6mm 3 core which was in orignally planned to be 10mm until he saw the price lol
he said Kid
will you run another to the decking we want some decking lights and wall lights on the back, but i want it fed from the shed another run of 15 metres at least but not straight he wanted me to dig a right angle trench
this is someone who gets his house plastered decorated wooden floors fitted wardrobes and then asks to sort his electrics ??
then onto the house to change the existing wylex 4 way wooden backed fuseboard and a volex split single for a new 13 way BG baoard dual RCD
then the fun really started and my black hair is deffo greyer
Burdens do 63mm black electric duct 50m for £50/60. Never liked to use blue poly after a farmer cut through one with a grinder to extend his "water supply". lucky man! The water pipe was 100mm to his left
I think that was the point we were making about making sure it is adequately marked with "electric cable below" tape. I agree, it is madness to simply run cable inside any pipework without adequate marking.
Reply to Garden supply in the UK Electrical Forum area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
