E
eckersecker
House I'm working on has water and gas bonded on same 10 mm green and yellow cable. It loops from the water to the gas. Is this acceptable or a code 3?
Discuss Gas and water bond. in the UK Electrical Forum area at ElectriciansForums.net
i thought they used a knotted rope.
That's not a sausage ye silly sausage ..................... it's a thing wot tells the pilot how high he's flying his aeroplane.
So what tells him he is flying too low,is it that scraping noise on the fuselage or all the vegetation on the windscreen
Surely this should have been posted in the DIY section?House I'm working on has water and gas bonded on same 10 mm green and yellow cable. It loops from the water to the gas. Is this acceptable or a code 3?
All you have to do is state qualification and code numbers and you will get answers whether your qualified or not.
DIYers paradise.
i looked at someones condition report that we had got hold of not too long back...It all depends,if its a continuous piece and is unbroken from end to end then its fine, if it has been cut to loop from the gas to water then it isn't.that's assuming you're not testing on behalf of BG in which case it's a fail either way lol.
I'm not kidding either,when I did some subcontract for BG I had a few that had been failed for one cable bonding both gas and water,it seems they make up their own rules to grab more cash.
If you have to be asking these kind of questions then in my opinion you are not yet competent enough to be carrying out EICRs (assuming that's what you're doing). My advice would be to get yourself a copy of BS7671 and GN3 and enroll on the 2382, the 2394 and the 2395.
For the record, one cable bonding multiple extraneous conductive parts is perfectly acceptable whether it is broken or un-broken in my opinion. Some may argue however that as soon as the bonding conductor becomes broken, it ceases to become a main equipotential bonding conductor and instead the link then between two or more extraneous conductive parts becomes a supplementary bonding conductor.
The call to make as to whether or not the installation is safe for continued use is soley down to the inspector, an inspector who should have a fundamental understanding of both electrical theory and regulation in order to be able to make an informed and reasoned decision based upon his extensive knowledge and experience.
My question to you:- What do you think? And are you comfortable enough to rely on your extensive knowledge and experience to back up your decision against all those who may question it?
theres an art to stacking produce you know..The rough translation of this is: Pack it in bonny lad and get a job at ASDA.
well....And every working day, there are more of these fast track/backdoor boys being churned out and officially registered as being competent by the very same organisations that were put in place, to put a stop to incompetents playing around in peoples homes!!!
It was a damned sight safer in the domestic sector, before these training centres and Part Pee providers got a toe hold in our profession, and that's a Fact!!
all labels facing front like.....
- - - Updated - - -
well....
you know my views on all this eng...
Reply to Gas and water bond. in the UK Electrical Forum area at ElectriciansForums.net
