Gas and water earth bonding | on ElectriciansForums
Discuss Gas and water earth bonding in the Australia area at ElectriciansForums.net
Just done some small work in a newly fitted kitchen,
There is no main earth bonding to gas and water. All plastered and decorated walls in an old stone building with no clear route from gas and water main inlets to consumer unit on other side of building. However, as part of the work, I disconnected a cooker circuit no longer required.
Is it possible to use the line and neutral of this 6mm t/e cable as an earth bond for the gas and water if correctly connected, marked and labelled at each end etc. ??
Problem is regs show independant 10mmsq cable for water and gas, so you wont do it with just the cooker cable. If both services are plastic incoming you may have another solution for say gas and then use that one for water but one way or another you need to get 10mmsq from each service to the MET. If anything is negotiable is the distance from the incoming service providing it does not branch out you could earth it further away.
Sorry cannot be more help
Can you use the cooker cable conduit to bring a 10mm earth down? If so, 1 x 10mm cable can connect both supplies if unbroken.
Will need to look a bit deeper i think.
So far can only find cooker cable in loft above kitchen (only ground floor there) then disappears through 3 foot former external wall into plaster at ceiling level with occupied flat above. After two more rooms it appears at consumer unit.
This ones easy. Get 4 meter longer bits of 10mm earth. Clamp one each to the gas and water and poke the other end into a hole in the wall. Connect the other 2 into the met and poke the ends into the cieling. Voila, bobs yer uncle main bonding and no mess......
Thats what the gas fitters ask me to do anyway when they wanna sign off a boiler.
Take with salt.
guys your missing the point entirely!!
never mind the 10mm sizing and independent cables crap (please read up on TT systems and bonding both services with one cable)
Earth Cable has to be G/Y through out its length, so utilising red/black cable is instantly a no no!!
so the fact is this
A) you have carried out works in a special location be it notifiyable or non notifiyable work
B) you failed to notice the missing bonding at quotation level
C) what are you going to say on the MW cert where it says "has all checks been carried out" "bonding etc"
best get the thinking cap on buddie!
so the fact is this
Was pondering the cable indentifier, what page does it say needs to be throughout its length, cos was struggling to find it.
Oh and whats special about a kitchen ?
514.4.2 Protective conductor rules...
and by special location = part p notifiable area (not as special as a bath or shower)
i would give it a code 2 as some Muppet might think its a redundant cable and chop it out!!
Reply to Gas and water earth bonding in the Australia area at ElectriciansForums.net
I like your way of thinking.
loz2754
L
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
