Gas and water main bonding
Hi,
I have a submain 16mm t+e and separate 10mm, question is submain comes from cellar up to ground floor, gas meter is next to incomer in cellar and water stoptap is other end of property....gas will be bonded to met at incomer but is it ok to bond water back to consumer unit on ground floor as this has a 10mm already going back.
i believe it is ok, or do the main bonding conductors always have to go back to 1 met or can it be done (which I believe it can as if you have a submain going out to an outhouse you can have combined earth and bonding conductor if extraneous parts are present)
I just can't remember if you can have only one met or not as I wouldn't normally do it this way lol
thanks
There is only one MET, by definition.
However it is possible (but not recommended) to have a joint in a bonding conductor (e.g in a consumer unit, joined by an earth bar!), it is normal to ensure that the bonding conductor cannot be inadvertently disconnected so it should be clear what is happening, e.g. have the two conductors in adjacent bonding conductor terminals.
This is not an ideal situation however it is a practical and permitted solution.
Jdsparky,
Richard Burns,
