Gas Boiler flue enquiry...... | on ElectriciansForums
Discuss Gas Boiler flue enquiry...... in the Central Heating Systems area at ElectriciansForums.net
Nikki
Glasgow
My gas boiler is wall fitted and is set up in my kitchen close to my sink. The housing association has done a half arsed job and the flue has yellow expansive foam coming out of it with no cover over it. I was putting lining paper up in my kitchen ready to be painted. I was trimming the lining paper around the flue area with a stanly knife and as i was doing so there was a loud bang and sparks. It has tripped one of my fuses in the fuse box. Im a little scared to put it back on. Can someone please help explain whats happened here? The stanly blade has black on the blade. I think i was lucky. Whatever i did i think it may have been fatal if i hasn't moved away so quick with the blade. I don't understand tho how the foam could make that effect. I wasnt cutting anywhere near a plug or around sockets. Just near this foam stuff around the boiler
[ElectriciansForums.net] Gas Boiler flue enquiry......
Hi Nikki - I'm glad you're still with us !
It's certainly not the foam that's caused a bang. I fancy I can see a power cable buried in it. If I'm seeing correctly it's showing at the bottom of the foam about 1/3 way from right hand end. If I'm correct it will need an Electrician to assess and repair it I'm afraid.
Thanks so much for a speedy reply. Can I ask... is this usual for electricians to leave open flues like this? is this a health and safety risk? if so I feel the need to rip the housing association a new one!
is it a rented property? if so, then the housing association is liable for putting that right. if you want a laugh, here's a housing association repair to a split purlin. as you can see, they've made no attempt to clamp/glue/support it, just banged in a few coach bolts, making the split worse and weakening the timber even more than before.
I think you need to be more concerned with the non-compliant nature of the flue sealing. That fitting is DIY standard.
If the housing association try to come back at you with a bill for damage to the cable, there should not be a cable in such a position that someone with a knife can damage it that easilly.
wilko,
I really cannot see that cable that's been mentioned. I've enlarged the image and still cannot see it. I think your seeing a bit of rubble stuck in that mess of expanding foam. Maybe I'm just blind.
Nikki,
in answer to your question regarding electrician leaving flue in this condition. An electrician shouldn't be touching boiler flues. Only a gas safe engineer can install boilers and their flues and test there suitability.
Peter
end of the day, that's an abortion of a flue installation and i'd be seeking retribution from whoever done it.
could send my cousin round.:
Reply to Gas Boiler flue enquiry...... in the Central Heating Systems area at ElectriciansForums.net
seems to be a big song and dance over this one guys, this is bottom basement stuff and seriously I cannot believe one the thread was put up and...
