Gas Bond Yes or No? | Page 2 | on ElectriciansForums
Discuss Gas Bond Yes or No? in the UK Electrical Forum area at ElectriciansForums.net
J
James Croxford
I have just carried out an EICR and the only C1 defect I found was no 10mm bond to the gas. As this is not a fixed gas feed but only a gas cylinder I guess this still requires an earth bond from the DB? (feeds hob only)
My next question is, if the rubber hose from the cylinder was to continue in plastic all the way to the hob would it then be exempt from having to have an earth bond at the cylinder?
Here's a picture I took yesterday....
[ElectriciansForums.net] Gas Bond Yes or No?
  • [ElectriciansForums.net] Gas Bond Yes or No?
The pipe work passes continuity (R2 lead test) as the hob is earthed through the fused spur. This would still be classed as an extraneous conductive part, correct?
James,
As the guys have already stated................bonding the pipework and the gas bottle would be the perfect example of 'introducing' a hazard by unnecessary bonding.
An earth fault on the system would /probably raise said pipework and cylinder to mains voltage(think aluminium double glazing in past years) and the poor sod that comes to change the bottle will be it's path to earth.........probably:)
here....
have a stug111:
or how about something classic:
Ah, the Sturmgeschütz III was a fine fighting machine, given the choice a brilliant selection for a tank commander to see through an ambush or a meeting engagement. The Jagdpanzer IV however with its better armour arrangement, longer range and faster speed made it a great weapon for blitzkrieg!
Personally however, with the freedom to choose from either side the tank I would most want to be in would have to be either a Hetzer or a Hellcat. Shoot and scoot is and always has been my MO!
Probably why I often like to bodge it and scarper :D
well...
i prefer to stand there and fight it out:
What a beautiful piccie !!
I have one of a WW1 Dreadnought sailing down the Tyne on its way to its sea trials after being built at the famous Armstrong's works.
Bloody magnificent sight - all smoke, might and majesty. I'm reminded of Tidyboiler every time I see it.
I've got a painting of a cocktail sausage......................... I'm reminded of Geordie........................ ;)
Reply to Gas Bond Yes or No? in the UK Electrical Forum area at ElectriciansForums.net
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
Recommended Sponsor News
Hi everyone,
