Gas bonding new flats | on ElectriciansForums
Discuss Gas bonding new flats in the UK Electrical Forum area at ElectriciansForums.net
marc8
Essex
Hello all
will be doing new block shortly, now I know you can do within 500 of meter, or at first point of entry to property.
They are running the gas through the screed & then up into flat next to water main there will be a gas isolation valve at this point & will then split for boiler & a point next to oven should someone require gas at later point.
My thinking with the emergency shut off valve this being first point of entry that will be fine, is my thinking correct ?
Hello all
Yes ideal, that will be before branch pipework too, so that sounds fine mate.
Reply to Gas bonding new flats in the UK Electrical Forum area at ElectriciansForums.net
Thank you, that's a really helpful post, nice & clearly stated and helps me clear up a lot of confusion on this matter.
2 3 4 5
6K
