Gas Bonding | Page 2 | on ElectriciansForums
Discuss Gas Bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The '600mm.' only applies to internal meters.
Not the point of entry - where practicable - or stopcocks or anything else.
Visible means able to be seen.
Of course you could make it permanent by welding it onto the gas pipe!
p.s. thats a skilled gas fitters/plumbers technique, so I dont advise any "electrician" doing it ...... infact I recommend you wait outside the house whilst they do it :wink:
Pah!!! ......... A little job like that is a piece of cake! ;)
I must admit to fitting a gas bond under the floor just after it entered the premises, as it was a third floor flat (converted big house) with the gas pipe running up the external wall.
Reply to Gas Bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This is an RSS feed of thread: Gas or Water Pipe? Look to find cause of damp in wall. Content of the thread: Hi all, First time post so please...
