Status
Not open for further replies.
Hi, quick posting - welcome any advice as new to this stuff...
Have a Howden HJA 0150 gas grill/oven with a broken thermostat that and can't get a replacement (grill igniting but no gas coming out of oven burners when on).
The Howden grill/oven is on a ring in the kitchen which has following appliances on it:
-microwave
-fridge freezer
-kettle
-toaster
-a Howden gas hob
-the busted Howden grill/oven
-couple of kitchen sockets generally not used
It all goes back to a RCD with a fuse that says - MTN132 b32 hanger fuse
There is an electrical wall connection for the grill/oven, with (I think) a 6mm wire for the ring (and not the thicker 10mm wires used for showers).
I may want to replace with just an electrical gill/oven. So some questions...
-Is there is max kilowatt oven that I could just wire into the current wall socket (which is used for the current grill/oven electrical ignition connection)?
-Would I need to replace the fuse in the RCD for the main? And is so with what?
-Would these things ensure the fuse would not trip if the oven was switched on?
-There are lots of electrical ovens but the instructions say they should be wired directly to the fuse box, so wondering if there is one which can just run from this ring main (if I upgrade the fuse)?
Would hate to buy an electrical oven and then its a nightmare and expense to fit it (the fuse box is currently full).
Welcome advice.
(attached pic of gas connection, and wall sockets for hob and grill/oven)
Thanks for past advice. Washing machine ordered for tomorrow (does not come with a wire) and assume there is calculation for a 2.3KW oven to determine the wiring requirement (2.5mm T&E would do the job I assume for 10A)?
Also those darn screws are not going into the backbox lugs easily and holding the front socket in, not sure if this is another newbie question - but if the back box is a bit warped is the suggestion to re-tap the lug thread or use something to fix it (removing the backbox would be a headache).
Most domestic sparkies carry a 3.5mm thread cleaning/reforming tool in their toolbox.
Ta - figured as much.
Almost there, just a query about lead installation from oven to wall FCU...
-2300W / 230v = 10Amps current expected through the electric oven lead at max.
-Understand that 2.5mm T&E does 24Amps circa (but not sure about unburied).
-Fuse in FCU would need to be 13Amps
If I have some spare 2.5mm T&E - this going to be okay for unburied oven lead to FCU?
Should I go for 4mm if unburied?
(BEKO manuals are flippin' useless and googlin is ambiguous).
2.5mm cable will be fine.
Hi, its all fitted a looks great. So thanks a lot for past advice(!)
Was a bit worried about the power wire on the back touching the oven when pushing it in.
But so far, no issues with it, or with any of the circuits tripping.
Did have another issue which someone on here may have an idea about?
The gas man who sealed off the connection said that was a small leak on the mains pipe that feeds the meter. He stuck some fairy liquid on it and there was a small bubble. I called Cadent who (after 4 hrs of messing around) changed the external pipping to the meter with some engineers during the evening.
The Cadent engineer then said there was a 2millibar drop showing and despite checking all the appliances with his sniffer (boiler, cut off gas seal for new oven, gas heaters, etc). cut off the gas on Christmas eve. I was horrified as there was no heating (even if the oven was working) on Crimbo day.
Does anyone know if they are allowed to cut the gas like this to a residential house when there has been no reported smell of gas, all appliances have been tested and the millibar drop on a tightness test is only showing 2millibar??
Status
