Gas meter replaced, then combi boiler starts leaking gas? | on ElectriciansForums
Discuss Gas meter replaced, then combi boiler starts leaking gas? in the Central Heating Systems area at ElectriciansForums.net
M
mikemack00
Hi Guys
I had our gas meter replaced for a new one the other day, and since then, when we turn on the central heating there was a smell of gas. I assumed that the gas meter wasnt fitted properly so I called out the gas company yesterday, however they have told me there is nothing wrong with the gas meter and that the leak is coming from the combi boiler.
Could it be that when he turned on the gas supply he has blown a valve in the boiler?
They might be pipe fiddlers but they're better positioned to answer gas questions than most on here.
I for one don't go anywhere near gas as I haven't a clue I think most sparks on here will be the same.
Good luck.. Let us know how you got on :smiley2:
All is possible but doubtful ,what may of happened is the working pressure was low before at boiler and now meter replaced with new governor,the working pressure is correct and maybe if boiler originally was not set up properly ,could now be over gassed,usually you would get smell of gas through flue
You say you are only getting smell of gas once boiler is on,so does not seem as debre from change over is in gas valve and causing it to let by
Presume your supplier came back and checked,if they did not isolate gas supply,does point to boiler not burning correctly as above
As we know,you get a lot of coincidences happen in the trades and you can be sent up a merry path if you link one with tuther sometimes
Obviously you should get a gsr operative in to check boiler asap and make any required adjustments or repairs and hopefully they will shed some light into what the actual cause is/was
What make and model is it ?
As said sure the lads on the plumbing forums will have other suggestions
Thanks for taking the time to respond Puddle, Gas safe engineer came out and found the gas pipe going into the boiler had a loose connector thingy me bob, must have worked itself loose? All sorted now.
Doubt it, sounds more like whoever changed the meter, purged the gas supply to remove air and never tightened it back up properly and didn't test to me ! Either that or change in pressure, but unlikely!
"Hello sam",
Although this statement from the OP is slightly confusing: `when we turn on the central heating there was a smell of gas` regarding why the smell of Gas only when the Combi came On.
I agree - that could well be exactly what happened - not retightened correctly after purging the Gas Supply to the Combi Boiler. This would also suggest that the Meter Installer obviously did NOT carry out a Manometer Test on the Gas Pipework / His connections on the Meter !
The thing about that - as You know - is that the smell of Gas should NOT have been related to the Combi being On - although I have come across situations where People have only been aware of a Gas Leak when the Boiler / an Appliance was On even though it would have existed for Days.
I wonder if it was what We suspect ? - and how much mikemack00 had to Pay the Gas Safe Engineer to rectify that ?
Regards,
Chris
I have had people say it was only smelling when on, but in fact the leak was on the pipework before. Not sure what the answer is, maybe they only realised as you say, or maybe there is a legitimate reason, like a small leak that passes more when the flow of gas increases etc. Also condensing boilers as you know pull gas through the supply pipe which is why you get a more significant pressure drop on the supply at other appliances, so maybe there is a reason?
I'd put money on the fact the meter engineer tested before he purged (if at all like you say!) and left the leak because he was in a hurry. Again like many posts on here, we may never know!
Sam
"Hello sam",
As You wrote - We will never know.
Please don`t be offended but I feel that I should explain something that You wrote - for the benefit of other readers on here:
Quote:
`Also condensing boilers as you know pull gas through the supply pipe which is why you get a more significant pressure drop on the supply at other appliances`
I KNOW that You mean High Input / Combi Boilers use a large Volume of Gas and require the correct size Gas Supply Pipe so that there is NOT a significant Pressure Drop at other Appliances.
Please don`t mind Me stating this - otherwise some People might think that finding a significant Pressure Drop on a Gas System where a Combi or other High Input Gas Boiler was installed was `To be Expected`/ Correct.
Regards,
Chris
Reply to Gas meter replaced, then combi boiler starts leaking gas? in the Central Heating Systems area at ElectriciansForums.net
A
Gas Boiler and Radiator Replacement I bought my house 31 years ago with its 8mm and 10mm micro central heating pipework and existing radiators...
Alan Wright
A
This is an RSS feed of thread: Combi Gas Boiler Intermittent Problem - Need to identify replacement part? Content of the thread: Hi All, Combo...
