K
k brooks
Can anyone tell me the best lugs to use for the termination of an outside 10mm earth to a gas pipe?
Discuss gas pipe earth. in the UK Electrical Forum area at ElectriciansForums.net
do you think your competent to carry out this work...then verify using measured against max. value.....if you cant even get the terminology rite?Can anyone tell me the best lugs to use for the termination of an outside 10mm earth to a gas pipe?
If you haven't got anything of any help to say then don't bother. ****
lol.....If you haven't got anything of any help to say then don't bother. ****
No not you. I was replying to someone else. I appreciate your reply.
All exposed cable to earth rod connections (apart from exothermic or braze welded connections) should be protected against adverse environment conditions. Depending on the type of connection made, either adhesive lined heat shrink, or correctly applied amalgamating tape, should be provided to completely encapsulate the connection...
That's lovely, but the question was about bonding to a gas pipe
wrap it with denzo...My bad....lol!! I'd go with a good coating of amalgamating tape to protect the connection then...
Just slip a condom over it and wrap it with Gaffer Tape.
Rather you than me, that stuff is bloody evil to work with!! lol!!
Reply to gas pipe earth. in the UK Electrical Forum area at ElectriciansForums.net
