Gas Supply Earthing | on ElectriciansForums
Discuss Gas Supply Earthing in the UK Electrical Forum area at ElectriciansForums.net
M
mark22
Hi All
After some advice please.
I am working on a block of flats and wanted to check that the earthing arrangements to the Gas supply is suffiecient.
The 5 Gas meters are all outside in those nice plasctics boxes they now use.
They are all in a line and the earth is looped in and out of each one, with the last box being linked to the main earth block.
Is this ok or as I would have done should they be run indivdually.
thanks
Mark
Is this a converted house into 5 flats??
Anyway, to my mind if these are designated as separate dwellings, then the services (Gas & Water) should be bonded as those services enter the flat or apartment. In other words each flat should be taken as a separate installation. If you check your on OSG's (or whatever they are called) it will confirm the above with i believe some nice illustrations....
Reply to Gas Supply Earthing in the UK Electrical Forum area at ElectriciansForums.net
Although the gas pipe may no longer require the bonding, it should really be terminated correctly or completely disconnected at the other end...
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
