General characteristics | Page 2 | on ElectriciansForums
Discuss General characteristics in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If a fault occurs in the HV system and a magnitude of fault voltage of 430v occurs between exposed conductive parts and earth on the LV installation, what is the maximum tolerable duration of the fault
Have a look at Reg 442.2.2 mate
25) If a fault occurs in the HV system and a magnitude of fault voltage of 430v occurs between exposed conductive parts and earth on the LV installation, what is the maximum tolerable duration of the fault
a) 10ms
b) 100ms
c) 200ms
d) 300ms
I don't know how to answer this one
What needs to happen generally under fault conditions, disconnection (ADS). You are looking for disconnection times.
Reply to General characteristics in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you, found it 👍
That'd be a great help mate. You could attempt to use chat gpt. Instruct it to rewrite the following and paste the lot in and 50% of the time it's...
