General Lighting Question
J.C.E
Am a 1st year apprentice and just want to get my head around the wiring of domestic lighting...
3plate: You take a 1.5 t+e from c/u to first lighting point (L,N,E) and then loop in and out of each lighting point (hench being called loop-in method aswell as 3plate?)
then take another 1.5 t+e from the light down to a 1way switch...brown is L, blue is SL, and green/yellow E.....but this is where I get confussed with where the brown and blue goes (when the terms perminent live and switch live I hear used!)
2plate: I beleive is the same as 3plate but you take a 1.5 t+e from the c/u to the first switch and loop each switch, then take a SW up to the lighting points...correct?
Is there a more common method that is used between 3plate and 2plate, why is this?
Then I know if you want 2way lighting, its just like the 1way I explained above but with a 3core from the switch to a second switch, C-C, L1-L1, L2-L2...... correct?
Then I am pretty lost with intermediate switching?!...so any help on this is wanted!
I very often read on this forum of sleeving blue switch wires on a new twin+E installation
Doesn't anybody routinely use twin brown for this purpose ?
Twin brown is made with switch drops in mind, and I find it hard to understand why, when suitable cable is available, that brown/blue is used so readily :confused:
Then having to sleeve a wrong coloured cable to conform to regs :confused:
Why break regs routinely to then have to sleeve to re comply by not using the manufactured cable for the job,economically it doesn't make sense and I can think of no other reason
It does not seem right that apprentices are schooled in conveniance wiring by mentioning routinely of oversleeving blues at the switch
I want another poll :D
Personally I would prefer to be able to easily identify which is the feed and which the switched live.
Also I can't be doing faffing around with all different cable types when I don't need to.
I guessing its because you can use t&e for blue and brown and for brown and brown (with the use of brown sleeving)
but you can't use double brown t+e for blue and brown (well without sleeving it blue)
so this answers itself surely!
