general purpose timeswitch help! | Page 2 | on ElectriciansForums
Discuss general purpose timeswitch help! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
what sort of sparky are you who is not able to figure out how the time clock works ? as all time clocks work in the same way having change over contacts from normally open to normal closed and the only reason for the link is if you are switching another supply that is not the time clock supply,and let face it you don't need to brain of England to figure out how it works do you ? as Tazz has indicated for you above, next time get a sparky in to do it for you m8 ok ?
I wonder how it all went today.......... let's just hope there's no Photo Cell or Movement sensor on the outside lights lol
I would slap the **** out of the 1st year apprentice for leaving cables like that. Take some pride in your work.
to be fair to the OP, i think he'd just got them in temp. to get it working, then would tidy them after.
if i remember correctly, the OP is either still in training or just out of his time,
Reply to general purpose timeswitch help! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
I doubt the terminals in those are suitable for 4mm, more likely designed for 1.5mm as they are limited to 16A. You could use the time switch to...
davesparks
