C
charliesutton
Hi all,
I've been to quote a job today and need some advice. Basically to give you an idea the customer has an old 50kVa army generator which he wants to use to power a new 3phase DB in his workshop, he wants 5 16a 3phase supply's for welders, mills and lathes, he's also wanting 3 single phase 16a supply's to power welders which is no problem.
Now the task in hand is what regulations with regards to earthing and RCD protection are in force for this situation, the reason I ask is because he has had RCD protection in the past and it tripped everytime he tried to weld on all 4 of his welders of which 2 were brand new. He's had someone out to it before and they have removed the RCD and fitted main switch, but I thought that supply from the generator would need to be 100mA RCD protected is this right? And if so will it trip everytime he tries to weld again.
Just trying to get some info on the regs regarding this situation.
Any help is much appreciated.
Many thanks in advance
Charlie
Charlie
