These get dimmer modules only seem to last year, I've put them throughout on two houses, I thought they were great, looked good and was very handy to have masrter slaves so you could dim both ends. However almost a year to the day I got called back to both houses with the same dimmer problem, ie , they were flickering on full power, I have a very sympathetic wholesaler who swaps over the switches for me when I bring the dud ones in. it's cost me 4 days so far. I fear putting in new versions of the same switch will only bring me back a year later to change it again, looking for an alternative I believe varilite do a master slave version. I don't beleave MK do. Are the new versions of these get dimmers sorted,,,
The house is full of the dimmers with Multiway Press switches that give a 2way dimming function using a RS switch line back to the dimmer.
Would the MK be the same? or do you feel if i replaced with a new type GET dimmer module then the problem would resolve?
Thank you for your time!
