Get your fuseboards out for the lads | Page 3 | on ElectriciansForums
Discuss Get your fuseboards out for the lads in the UK Electrical Forum area at ElectriciansForums.net
Joshua
London
Just a little way to pass the time on Saturday lunch time
Go through your pictures and post the most recent fuseboard picture you've got.
This is mine which I done on Thursday.
I spot 4 snags. Without including that main earth (The Main contractor wouldn't supply earth terminal crimps)
[ElectriciansForums.net] Get your fuseboards out for the lads
One would assume that the screw is the earth connection to the body of the board as installed by the manufacturer.
I am interested that you were not worried by the exposed copper on the RCD incomers and unused busbar.
How did you extend the storage heaters' circuits?
Yes that screw is the manufacturers means of earthing the steel enclosure.
I'm not totally happy with the copper on show in the RCDs Richard but the conductors are fully home in the terminals and they're the very fine stranded copper crimped together at the ends so to shorten them would be a faff and anyway nobody should be poking around in there without the main switch off.:) The spare ways had the proper Hager blanks fitted which clip onto the din rail and fully shield the busbar prongs after I took the picture. The storage heater circuits which are now radials feeding individual sockets and labelled up in great detail were extended in the void behind my backboard using Ideal maintenance free connectors, I thought this fine as it's totally inaccessible with the CU fitted and there's no strain on the cabling.
Looks odd just seeing the neutrals with all the lives tucked in behind, not keen on those rear hidden terminals as I like to see the conductor is in properly when tightening.
Reply to Get your fuseboards out for the lads in the UK Electrical Forum area at ElectriciansForums.net
