getting down(or up) inside a stud wall.....long flexible drills? | Page 2 | on ElectriciansForums
Discuss getting down(or up) inside a stud wall.....long flexible drills? in the UK Electrical Forum area at ElectriciansForums.net
B
brman
I am trying to find a better way of getting cables down inside an existing stud wall. At the moment I am cutting an access hole below each noggin to allow me to drill and feed the conduit/cable up but would rather not have the hassle of making good.
I have seen these extra long flexible drills (or rigid extension rods), do they work?
Am I likely to be able to get down an insulated stud wall without getting the insulation all wrapped around the drill and how do you ensure they stay on track and keep in the correct zone?
If they are worth it, any suggestions on where to get one from? (googling hasn't been particularly helpful....)
Been using the 6 foot 3/4 inch flexi drill for years. Insulation in the walls can be a bit of a problem I usually drill 2 32mm holes in the top of the wall and use a piece oval conduit through one to push the insulation back then send the drill down the other
Can be a problem taking lumps out of walls that have just been decorated customers always tend to work the wrong way
I'm a craftsman mate, don't use nails! :)
allrite then clever dick.....
[ElectriciansForums.net] getting down(or up) inside a stud wall.....long flexible drills?
all wrong.... too fiddly. twin blade wall chaser top to bottom. remove the 1" wide P/B strip. replace with 1" minitrunking ( cable inside) then a quick gob of filler down the front.
Reply to getting down(or up) inside a stud wall.....long flexible drills? in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
