slectrical
Hi,
My hot tub keeps tripping after 12 years of use. I'm thinking it's the GFCI gone bad. Unfortunately it's a CH 2 pole 50 amp (GFTCB250) and they are on national backorder. The only options I can think of are to put a GFCI in the main panel (Sqaure D) and replace the GFCI at the disconnect with a standard breaker but I'm not sure if that can be done. The other option is to replace the entire disconnect with a new one that has a GFCI. Perhaps something is wrong with the hottub as well but everything had been working until we switched the breaker off to drain the tub. Any thoughts on what can be done?
TIA.
TIA.
