GFI keeps tripping | on ElectriciansForums
Discuss GFI keeps tripping in the UK Electrical Forum area at ElectriciansForums.net
At home
I wired my garage this summer. Installed panel, laced it in. 24 circuits. Over 200 plugs lights ect. No issues. It all works fine
Except 1 circuit. 15 amp runs from panel to 1 gfi. Loads out to basic 15 amp plug. From there to gfi number 2 in the bathroom. In on the line terminals of course. Load out to 1 more basic 15 amp plug , then off to run a switched fan.
When I power up circuit, gfi 1 trips. Never the breaker. I remove gfi 1 then either direct connect the hot/neutral in the box or install a basic plug in the gfi 1 box. No problems. Circuit works great. Gfi 2 never trips. Loads out to plug and switched fan fine. Put any gfi back into gfi 1 location, gfi trips. Never the breaker.
Any ideas? I could always just marett the hot/neutral in gfi box 1 and put a full cover on it and call it a junction box as it's not really needed but I am puzzled and would like to find out what's going on. Tested all plugs with a neutral short to ground, ohm test plug in tool. Get ok on every plug
Why? Electricity works the same way around the world. V=IR in all countries plus there is a way better chance I’ll get more views if it’s also outside of Canada.
Very little is the same to be quite honest which is obvious from your post. Westward is only trying to help you to get better advice relevant to you.
Reply to GFI keeps tripping in the UK Electrical Forum area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
Ok I’ll try this when I’m down
