Gland ?????????????? | on ElectriciansForums
Discuss Gland ?????????????? in the Electrical Tools and Products area at ElectriciansForums.net
Cheers Dave, had a look but couldn't find what I'm after.
its for a garden spike light with flex which will be going in to flexi conduit, so to fit conduit one end and compression fit flex other.
  • [ElectriciansForums.net] Gland ??????????????
The only way I can think of achieving that would be to a glavanised coupler or two of these glued back to back.
thanks for the input, i could use a coupler and some PTFE tape if i cant find a gland, would prefer a gland though
I had a quick look on RS to see if there was anything more suitable... I only looked at the Adaptaflex range and they didn't have anything that would make the job easier. It's a bit strange as I highly doubt your the first person to want something like this.
I've used these for flexicon, a dab of silicone, never had any problems:
Reply to Gland ?????????????? in the Electrical Tools and Products area at ElectriciansForums.net
yes it was a pee-take... I was commenting if someone was dumb enough to use earth clamps on armour, they might just be dumb enough to earth a...
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
