Gluing alarm cables to UPVC Window frames & Door architraves
Mitre fast would be ideal in this situation. Comes as a 2 part kit, 1 bottle of superglue and one can of aerosol activator which makes the glue go off within a couple of seconds.
Hello again Resu,
Thanks for the recommendation / information.
I really appreciate your thoughts on this and I am not trying to contradict you or be awkward but what do you think about this:
I would be concerned that trying to apply a line of Superglue down the cable route [on the UPVC moulding / trim] and then spray it with activator could cause a very messy / undesirable situation before I even got a chance to try sticking the Alarm cable to the activated Superglue ?
Also - would you guess that the overspray from the activator spray would just wipe off the brilliant white UPVC without discolouring it ?
When I attempt gluing the cables onto the UPVC frames / architraves I will have fixed the Magnetic contacts to the bottom of the `mouldings` and the cables will be routed up through the ceilings [following an exactly vertical line] with enough slack to push them onto the adhesive.
After they have adhered to the shape of the frames / architraves I will pull the slack up from above.
I have described that because I would not really be able to apply the Superglue and activator to the Alarm cable and then stick them onto the UPVC frames / architraves as the cables need to be connected first to the Magnetic contacts.
Thanks again - I would be grateful for your thoughts on my questions please.
Chris
back on track, i'd just use a bit of the 12mm x 5mm sticky back mini. trunking. non permanent so can be removed if desired with no melting of the pvc frame which could invalidate any warranty.
Hello again Resu,
Chris
I'd go for: line of glue on frame, place cable on top, quick spray with activator. Activator should effectively evaporate but should wipe off no problem if not.
Would be worth a test in a discrete corner if you're worried.
Hello telectrix,
Thanks for your message.
The Window frames and Door architraves are made from pieces of moulded UPVC `trim` which are fitted around the windows and doors - apart from a section closest to the window and door which measures 35mm x 5mm there are no flat surfaces to use any size of mini trunking.
Chris
Hello again Resu,
Thanks very much for replying to my question about using your recommendation `Mitre Fast` regarding the use of the `Activator` spray.
I have the Alarm Magnetic contacts wired up [cables clipped to joists in floor voids above] and hanging down from ceiling to Magnetic contacts with enough slack to be able to glue them to the UPVC frames and architraves so now that I know what adhesive to use I can glue the cables whenever I get the Mitre Fast adhesive.
I know that You recommended this product much earlier in the duration of this thread but as it was a Superglue type adhesive I wanted to carry out my `Test` to ensure that type of glue did not damage / melt the pvc insulation of the Alarm cable or damage the UPVC.
Thank You very much for persevering with your recommendation and for helping me with the answer about the `Activator spray` - I have an offcut of UPVC so I can try the spray on that to ensure that it either evaporates or can be wiped off without staining.
Chris
in this situation i would have installed a wireless alarm system, such as the Risco Lightsys (hybrid) or Agility (totally wireless). problem would never arise then.
Hello again telectrix.
In my original message that began this thread I explained that I was having to fit Alarm Magnetic contacts to some of my Home`s windows and doors because the wireless Alarm`s RF receiver had failed - it was no longer receiving the transmissions from the few wireless detectors that I had left on the system.
Either in that first message or in a subsequent one I described how over the last 20 years various wireless detectors had malfunctioned and that because replacements were no longer available from the Manufacturer I had to `hard wire` either new PIR Detectors [Honeywell] or Magnetic contacts to the Alarm Control Box.
My Alarm system was purchased as a `Wireless Burglar Alarm system` but luckily for me it also had the facility to add wired detectors or it would have become useless many years ago.
Because of my experiences with a `Wireless Burglar Alarm system I would never have one again.
I realise that there will have been a lot of improvements in wireless Alarm systems / wireless detectors and I know from your and other Members comments that the systems that are now available would be much less susceptible to external RF interference than my previous wireless detectors and probably more reliable regarding `malfunctions` - although some of my wireless detectors did last for 20 years until the Control Box stopped receiving their transmissions - which I view as almost `miraculous` regarding my previous expectations of `Electronic products`.
Chris
just out of interest, what make is the defective alarm system?
chris murphy,
Tuxornot,
