GN3: IR test, whole installation vs final circuit
Forgot about this!
Re: the CPCs being connected to Earth, No, but what you said is good.
I'm thinking of, if they weren't and there was a fault of the old negligible impedance ...
Forgot about this!
Not quite sure i follow you here!
If we are carrying out Insulation Resistance testing then the circuit or circuits (depending) will be safely isolated from the supply.
I may be missing something very obvious here though. Thanks:smile5:
Last clue.
0 Ohm L-E fault, cpc not Earthed, put 500V on it, what's the V on the cpc/exposed parts?
Other trades wandering around...
