Going for NICEIC Registration at long last. | on ElectriciansForums
Discuss Going for NICEIC Registration at long last. in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
T
Twistedfinger
At long last I am finally getting around to applying for NIC approval. I've been meaning to do it for ages but "other " stuff kept getting in the way and delayed the application.
I've just been re reading the Guide and one part has me worried. There is a paragraph that says:
"How you have complied with notifiable work under the Building Regulations"
Now as I set about on this quest a while ago I took on some domestic DB changes with the view to timing the installations with my application so as to allow time for notification to building control when I was approved. I only took these on so that I had more jobs on the books and so that I could present a good range of works. I usually do mostly industrial with some commercial so it seemed like a good idea. Now with a couple of these jobs 6 months old and well outside the 28 day notification period the above comment got me wondering. My instinct is to re do the greens so as to get the timing right, and to be honest this is the way I'll probably go ( I know both house holders so I can't see it being a problem for them) I was wondering though how the inspectors have been with other applicants in similar situations i.e domestic "part P" works done by non part P electricians.
Do Niccy turn a blind eye or am I in the lap of the gods if the inspector suspects something dodgy ?
Twisted
And.... Its down to you when the job is "finished". Nudge nudge wink wink. Then and only then are you supposed to notify, so over to you, you may have started those jobs six months ago.....
blow the dust off the board and change the date, inspector wants to see a tidy job and probably more interested in the paperwork in the year ahead, especially paperwork with the queens head on it ....
Reply to Going for NICEIC Registration at long last. in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
NICEIC Certification Scheme Getting accredited to
I am in almost the same boat, although I am registered for a scheme, and as I have been continuously, I have been told no NVQ required... BUT...
"So the question is to register with NICEIC/NAPIT for part P regs will they require other proof of qualification?" Why not contact them and ask...
