Gold card recognised ?? | on ElectriciansForums
Discuss Gold card recognised ?? in the Ireland area at ElectriciansForums.net
London
Hi lads does anyone know if the gold card is recognised in the Republic of Ireland aka south of Ireland
Recognised in what sense? If it's to cover health & safety then most should accept with appropriate explanation that it should be OK as an equivalent to a Safe Pass.
I'm moving to Cork next year just want to know would I have problems getting a job with the gold card or do I need a QQi fetac level 6 cert
I don't believe you should have any issues so long as you can present evidence of your qualifications. Assuming you've served an Apprenticeship then there shouldn't be an issue with this being recognised.
Reply to Gold card recognised ?? in the Ireland area at ElectriciansForums.net
    • Friendly
Thank you. I think I understand now.
Hi, Has anyone come across DIY balcony solar panels? These are solar panel kits you can buy that plug into a regular electrical wall outlet...
  • Yoult1976
  • Ireland
  • 0
  • 195
